Configures the default 1 Gbps auto-negotiation mode to enabled or disabled (the default) when 1 Gbps optics are inserted in 10 Gbps ports.
on | Specifies that the default 1 Gbps auto-negation mode is enabled. |
off | Specifies that the default 1 Gbps auto-negation mode is disabled (default). |
N/A.
Use this command to configure the default 1 Gbps auto-negotiation mode when 1 Gbps optics are inserted in 10 Gbps ports. The default mode was changed to off In ExtremeXOS 31.4 for Universal switches, which can lead to interoperability issues with older releases of Switch Engine and mixed deployments with ExtremeXOS and Switch Engine devices, where 1 Gbps optics are inserted in 10 Gbps ports. The new default auto-negotiation mode takes effect on 1 Gbps optics inserted in 10 Gbps ports after the CLI command execution finishes.
The following example sets the default auto-negotiation mode to on.
configure ports auto 1G-optics-in-10G-ports on
This command was first available in ExtremeXOS 32.7.1.
